Trans Am Tails
Old Aug 30, 2006 | 01:17 AM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
Trans Am Tails
Which lights are the turn signal lights? I know the ones by the center section are the revers lights. The way I have it now, is the 2 middle lights are the brake and tails, then the very ends are the turn signal. Just wondered if that was the way it is supposed to be. I have the luxury of changing them around. Here is the way they are:
TS-B-B-R CS R-B-B-TR
Old Aug 30, 2006 | 11:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The grid lamps were- outer:marker, middle+inner:turn/brake, obvious:reverse.
The 91-2 Formula/Gta lamps were- outer:turn (yellow lense), middle+inner:marker/brake, obvious:reverse.
I wired my grid lamps like the 91-2... it was the easiest route (for me) using the base lamp wiring. You will have to replace a lamp socke or two, though.
Some rrelated reading to what I did... https://www.thirdgen.org/forums/auto...highlight=tail
Old Aug 30, 2006 | 11:44 PM
Car: 89 formula 350
I did mine like the 91-92 also, just looks better.
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
theshackle
Aug 23, 2015 03:49 PM
Fronzizzle
Aug 19, 2015 01:36 PM
