2000 Camaro Vats problem?
Old Sep 2, 2006 | 11:18 PM
bear61255's Avatar
Car: 2000 Camaro
Engine: 5.7
Transmission: automatic
I went out to start my car and it will not crank. All the instrument panel lights are working, but my security light is flashing. I have checked the starter,solenoid,neutral safety switch,starter relay and fuses. Went to the dealer and had a new key made. Still cannot get car to turn over. I was told maybe it way a VATS problem. Is there anyway to bypass this without having to replace the ignition cylinder? Also I was told that there are problems sometimes with the wires from the ignition breaking. Any suggestions?
Thanks Bear
Old Sep 3, 2006 | 12:48 AM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
2000 huh lol i dunno if u noticed but this site is dedicated to 3rd gens (82-92) hence the web site be named thirdgen.org....... just my 2
Old Sep 3, 2006 | 10:22 AM
bear61255's Avatar
Car: 2000 Camaro
Engine: 5.7
Sorry, I did not notice. I will look for help elsewhere.
Old Sep 3, 2006 | 01:30 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
gee you guys are nice..
thats usually an issue on the c5's but could very posibly be the reason for it not starting. jus go in there and check the wires.
PS -check out ls1tech, much more helpful than here. hope it helps
Old Sep 3, 2006 | 06:36 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
You can use the same resistor bypass as the thirdgen cars. Mike
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
