ALTERNATOR HELP PLEASE
Old Sep 3, 2006 | 03:50 AM
STEVE OC's Avatar
Hi Guys
I hope you can help , I have a 1986 305 tpi iroc , today I had my engine idling and the battery gauge was showing only about 11.5 volts , I checked the main wire at the rear of the alternator and it was very hot , I stopped the engine and let it cool down and then restarted it this time the wire stayed cool , I then put a volt gauge across the battery terminals but the voltage remained at 11.5 volts even when rpm was raised , do you think it is an alternator or a wiring fault , any help appreciated . Steve
Old Sep 3, 2006 | 04:09 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
well, myn is doing the exact same thing
Id double check to make sure your belt is tight...
If not its probly time for a new alternornator there like 70 bucks so u may as well replace it because 11.5 will drain the battery pretty bad.. in fact myn barely started one day because of it
anyhow hope it helps
Old Sep 5, 2006 | 11:28 AM
BigDreams92's Avatar
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
You checked voltage across the battery, but what was the alternator putting out at the post?
Verify grounds, good electrical connections and belt tension like stated above.
Old Sep 25, 2006 | 01:28 AM
STEVE OC's Avatar
Found the problem , stripped the alternator down and found the screws were out of the rectifer replaced them no more problem
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
