Column swap, non vats to vats
Old Sep 7, 2006 | 01:07 PM
homerunchamp's Avatar
Car: 2007 Dodge Charger R/T
Engine: 5.7L HEMI
Ok here goes, I have been searching but have come up with no clear answer to thiss question. I have a 91 RS with Vats, and am picking up an 88 Iroc which I believe is non Vats correct? (havent picked it up yet) The Iroc body is nice so I am swapping all my parts to the Iroc from my RS, 5speed glass etc. The steering coulmn on the Iroc is trashed from some idiot trying to steal it, and I wanna swap it out with the one from my 91 RS. Is this possible or will I run into problems? CAn you run a colum equiped with Vats in a non vats car by simply not hooking up the vats system? Thanks in advance for the help.
Old Sep 7, 2006 | 01:32 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
I believe the short answer is yes. VATS works off two small wires from the column to the VATS module which sends a signal to the ECM. If you're using the '88 ECM (non VATS), you should be OK.
Old Sep 7, 2006 | 05:14 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Leaving the airbag wheel off may leave a gap between the wheel and coulmn. But the coulmn would work just leaving the VATS wiring unhooked. Mike
Jorlain
Aug 24, 2022 05:11 PM
Street Lethal
Apr 30, 2019 12:14 PM
Out-Cast
Mar 22, 2019 09:39 PM
Pemberton76
Aug 15, 2015 07:15 PM
stalkier
Aug 13, 2015 12:59 PM
