Weird blinker annoyance
Old Sep 9, 2006 | 12:45 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Well,,, my left turn signal indicator (on the dash) stays lit when my lights are on. It doesnt really affect my signaling but its really annoying! Oh yeah, and I just noticed that my front left flasher doesnt work either. I changed the bulb too. Has anyone experienced this problem?
Old Sep 9, 2006 | 01:29 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
It sounds to me that you have a bad socket in the front.I have seen the ground tab break in these sockets and cause exactly what you described.I hope this will help.
Old Sep 9, 2006 | 02:53 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
What is the front socket and where is it located? I'm not to sure what your talking about...
Old Sep 9, 2006 | 07:13 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
The socket in the front flasher lamp where you just exchanged the bulb, of course...
Always when you replace a bulb, you inspect the socket in the lamp.. The bulb may not even be broken, it could just be an oxide layer, make sure all contact points are shiny.
Most flasher relays are made so that it stays on if one of the bulbs are out. The indicator staying on (in the dash) is an indication of this fault condition. So I presume it did affect your signalling, or did it actually flash outside while staying on inside..?
Old Sep 9, 2006 | 08:34 PM
cadman277's Avatar
Car: 95 z28,86 iroc
I am sorry for not indicating the l.front t.signal lamp socket,I wish I had said that earlier.Did you chang out the socket and did this fix the problem?
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Yes, now that I looked at it..... It did affect my signaling. The blinkers on the dash worked properly but the signal lense was not flashing. I just went and inspected the socket and it appears to be missing the little metal tab that should be attached to the contact. So I am gonna go to autozone and buy a new socket. But Im really not sure on how to remove the socket. Its connected by 3 wires that feed into 2 small rubber boots. Do I have to cut the wires or should they just pop out with the whole boot assemblys?
Old Sep 9, 2006 | 08:40 PM
cadman277's Avatar
Car: 95 z28,86 iroc
The new socket should have the wires connected already,all you have to do is match them up.{The new wires are probably the same color so make sure you match them up to the old socket.}I would suggest soldering and using a heat shrink that seals so there is no water intrusion.
Old Sep 9, 2006 | 08:48 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Cool man,,, Thanks for all the info. I'll see how it goes tomorrow.
Old Sep 10, 2006 | 08:07 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Well I installed both of the new sockets, but now my right front signal doesnt work. I am thinkin that the side signal that never worked is throwing off the front signal. I tried to remove the lense but I felt like I was gonna break it. Is there any particular way to remove the yellow side lense?
F-body-fan
Today 10:12 AM
GTAman
Jul 3, 2024 07:29 PM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
