headlight wire help fast!
Old Sep 10, 2006 | 05:16 PM
1fast97gsx's Avatar
I'm in the middle of making a custom wiring harness for my car and I can't figure out one wire. From the headlight switch there is a yellow wire that the diagram shows going to the dimmer switch. Then there are 2 wires that come out of the dimmer switch ... 1 for high beam, 1 for low. I don't see a yellow wire coming out of my steering column though ( dimmer switch wires are inside the column ) other than the rear turn signal wire which IS yellow, but not the one I need.
Here is the diagram :
I need someone to tell me where that yellow wire from the headlight switch runs on their car so I can finish my harness. Mine is a 1992 z28 but I'm sure most of them are the same.
Figured it out ... I was missing the connector for the dimmer switch.
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Catcher55
Aug 15, 2015 07:08 PM
stalkier
Aug 13, 2015 12:59 PM
