turn signal flasher location 90-92 firebird
Old Sep 10, 2006 | 10:58 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I'm hoping this is the problem why they don't work. my hazard lights flash but the turn signals only light up but never flash. So where is this flasher located, is it in the convienence center or up in the dash somewhere.
Old Sep 10, 2006 | 11:16 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The turn signal flasher is either in the conveince center or just to the left of it next to the steering column.I get the hazard flasher and the signal falsher mixed up.But from what you say the flashers are doing sounds like you have a bad bulb.Do either of your turns signals,left or right work?Worst case is a bad turn signal switch in your column.But I'd check the bulbs and the flasher modules first like you are doing.
Old Sep 11, 2006 | 08:40 PM
Jproz1167's Avatar
all turn signal bulbs including front side fender signals flash when moving the turn signal switch to manually make them flash. but if you push down on the switch they just stay lit up but never flash.
also while on the lights subject when i press the parking light switch the head lamps raise however the headlights dont come on until i press on the headlight part of my switch. see this 82 transam has 91 electrical harnesses, so I'm wondering if the headlight thing is acting normal as well.
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
