Wiring up VSS
Old Sep 17, 2006 | 06:31 PM
cdoyle's Avatar
Wiring up VSS
Hello again,
Another question on this dash swap, for the 91 dash I'm putting in I need to switch to a electronic speedo.
I got a VSS unit, and it has 2 wires on it. 1 is blue/org and the other is blk/white.
Do I just run these up and connect them to the wires on C100? I'm looking at a 92 C100 diagram D4 YELLOW says Vehicle speed sensor And E4 PPL Vehicle Speed sensor.
If I do just connect them to these 2 pins, since the colors don't match to what I have on the unit. Does it matter to which wire off the VSS hooks to on the C100?
Thanks again
Old Sep 17, 2006 | 06:52 PM
cdoyle's Avatar
Nevermind, I think I found the answer.
I hooked the VSS up to a drill, and then hooked the 2 wires up to Yellow and Purple wires. It didn't seem to make a difference to which wires they were hooked too, just both had to be connected.
Thanks again.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
Bryan F
Aug 27, 2015 07:28 AM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
