Voltage Drop in Reverse???
Old Sep 18, 2006 | 05:03 PM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
Ok like the title states i'm having a voltage drop when i put the car in reverse could this be cause by the reverse light switch or other?
Old Sep 18, 2006 | 08:50 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
How large is the drop? Is it a volt or 2?
Old Sep 18, 2006 | 09:40 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I get all kinds of voltage drops when I do various things. My meter bounces back and forth when the blinker is on, it goes down in reverse, etc etc. I would say its normal but we might want to get some more opinions...it depends on how much it drops!
Old Sep 19, 2006 | 10:10 AM
Mr.Wolf's Avatar
Car: 87 Z28
ya mines does that when i hit the blinkers, when i throw her into reverse she drops down halfway between 13 and 0.
Old Sep 19, 2006 | 03:04 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Well yeah that would be about 6VDC. Thats not good either. Here is a few things you can check and this is the order I'd do it. Also this applies if the 6VDC drop is just in reverse.
1. Check with a Meter at the battery when in reverse exactly what your getting. Your gauge maybe jacked. Maybe problem solved!!
2. Check your brake light switch under the dash, something could be shorted out there aswell
3. Check all your reverse lights (bases and wires) for shorts. You maybe getting a voltage drop there.
4. Either update your battery, if its old and also have your alternator checked
Now this is just my personal opinion on how I'd go about solving this issue. Someone else may have a better way or whatever, but its a start.
Keep us posted.
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
