Fuse Keeps Blowing
Old Oct 7, 2006 | 06:28 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Fuse Keeps Blowing
The car is a 92 RS. One of the fuses keeps blowing. Its the fuse that controls the interior lights, power door locks, power hatch, etc. It has blown out a couple times before but now I can't even put a new fuse in without it instantly going bad. I tried to put a 30 amp in there but it also went bad. What do you guys think the culprit is here?
Old Oct 7, 2006 | 06:39 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
honest to god, check for a penny or something in your cigarette lighter outlet.
Edit- Also, if you have an aftermarket radio, check the wiring job.
Old Oct 7, 2006 | 07:22 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
Every time I turned on the headlights, I would blow the fuse that controlled the instrument lights. Turned out the wire that went to the stereo that dimmed the display when the headlights went on was grounding out.
Old Oct 9, 2006 | 10:33 PM
88ragtop's Avatar
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
I had the same exact problem and same things that would blow. I unplugged the wire to the cig. lighter and the problem went away.
Old Oct 9, 2006 | 11:20 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Under hood light fixture was shorted to ground for me. Removed the wire from it and haven't had a problem since. I'm still looking for a new fixture (low on the priority list).
Old Oct 10, 2006 | 05:27 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Sounds like you have a dead short to ground. Put a test light across the fuse terminals & it should light up. Go around and disconnect devices on the circuit until the light goes out or wiggle wire harnesses until the light goes out. When the light goes out, you have found your problem - please do not put a bigger fuse in the circuit or you will find your problem by way of fire!
Corky
Old Oct 10, 2006 | 12:23 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
The car does have an aftermarket cd player. Thanks guys, I will follow up on your suggestions and let you know what I find.
Old Oct 10, 2006 | 11:07 PM
detltu's Avatar
Car: 92 Camaro Z28 1LE- Z03
Transmission: 5spd
I'm running into this problem right now. My car is an electrical nightmare. I think my problem may be that water got into my electric side mirrors when I had to pull the driver side off to go get a new mirror. I haven't figured it out yet and I have some other problems to figure out. Whoever had the car before me did a terrible job wiring in their stereo equipment.
Old Oct 11, 2006 | 02:19 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Well okay Im outside trying to find the problem. I took the radio trim piece and shifter plate off. The radio wiring job looked fine and I made sure the power window/trunk connections were good. I checked the underhood light and all looked good. I put in a new fuse and it was good for a minute or so and then it blew. Then I was messin around the guage cluster area. I made sure the rear defog connection was good and unplugged the wire going to the cig lighter to see if that could be the problem. I put a new fuse in and it was good for 4 minutes then it blew. Why would the fuse stay good for a little and then blow again?
update-I took the bulb out of the underhood light and so far the fuse is still good. So hopefully that is the problem.
Old Oct 11, 2006 | 08:01 PM
Toehead's Avatar
if it is a random blow it is most likely a wire that has the insulation rubbed off which shorts at random times.
Old Feb 18, 2007 | 07:17 PM
sprtbikeprinces's Avatar
Car: 1990 RS
Engine: 305 tbi
This must be one of those "camaro traits". I am not a violent girl but all of the fuse changes that I did on my car...It was about to get ugly! hee hee! Thanks for the under the hood light trick, I'm gonna try it! Hope it works for me too!
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
