My ignition coils keep burning out
Old Oct 10, 2006 | 01:59 PM
Vern's Avatar
I have a 1988 Coamaro with a 2.8 V-6. My problem is I keep replacing my ignition coil. I've replaced my spark plugs, rotor, distributor cap and module in the distributor. Can anybody help.
Old Oct 12, 2006 | 06:06 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Make sure the coil has a good ground (you can run a temporary ground to chassis). Not sure if you are buying Auto Zone type coils, but you may need to purchase an OEM coil & see if it survives.
Corky
Old Oct 12, 2006 | 06:07 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Make sure your grounds are good. Check the engine grounding straps to make sure your block is grounded well.
Old Oct 13, 2006 | 12:13 PM
Vern's Avatar
What is an OEM coil.
Where are my engine grounding straps
Old Oct 13, 2006 | 01:24 PM
Toehead's Avatar
It is a braided cable that runs from the middle of the firewall to the intake manifold, towards the rear. there is no insulation on it, it is bare metal.
MM2Robinson
Oct 1, 2017 09:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
