Controlling the Torque Converter lock up?
I'm installing a holley commander 950 standalone engine management in a 87 Iroc. How do I get the torque converter lockup to function properly with out the use of the factory ecm?? Can I keep the factory ecm partially connected to control the lockup function or will it not work properly?
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
get a b&m lockup converter switch, its killer good gas milage, bypass the ecm. laters
Dialed_In
Aug 20, 2015 01:45 PM
