Help with EST wire! Won't run with it connected.
Old Oct 16, 2006 | 02:25 PM
Spooled's Avatar
I transplanted a TPI setup into my chevy truck. IT's from an 86 TPI I believe. It won't hardly run with the EST wire connected. Disconnect it and it runs fine. I might have a wire hooked up wrong somwhere. I didn't hookup the knock sensor. Any clues? WHat/how should I check to see what's going on. I can't seem to figure it out. I'm about to the point of setting the timing to like 32 degrees and leaving the est wire disconnected. Might have to put my ign on a switch so it'll crank over. Please help. Thanks fellas
Old Oct 17, 2006 | 06:23 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
TRY HOOKING UP THE KNOCK SENSOR,I BELIEVE THIS IS REQUIRED TO RUN YOUR 86 SETUP
Old Oct 20, 2006 | 08:43 AM
Spooled's Avatar
it ran fine before on my other truck and it never had the knock sensor hooked up.
Old Oct 20, 2006 | 08:59 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
What is the base timing set at with the EST wire disconnected?? If its set properly, your balancer might have slipped.. You might want to verify that #1 TDC is actually reading 0* on your balancer..
Old Oct 20, 2006 | 11:03 AM
Spooled's Avatar
I've been moving the timing around. It doens't matter what it's at. It won't run with the EST wire connected. I thought it might have slipped but that doens't change the fact that it will not run with it connected and runs perfectly when disconnected.
Old Oct 20, 2006 | 11:10 AM
thirdgen88's Avatar
Car: 1995 Corvette
I wonder if there is a problem with the ignition module... You might try swapping one out with a known good one... Could be that the module isn't reacting properly to the advance signal from the ECM??
midge54
Dec 27, 2019 04:14 PM
camaro11j
Sep 19, 2018 08:49 AM
Caspar
Jun 19, 2016 11:19 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
