Horn not working???
Old Oct 16, 2006 | 03:06 PM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Horn not working???
Hey...I bought a horn for my car and I know it works because I tested it on a car in the Junkyard before I bought it...so...I hook it up and it still dosnt work...I'm thinking it's the horn relay that needs replacment...I know its something like $11 from GM no biggie...but where is it?...I hope it's not in the steering column because I've seen that thing taken appart before and it looks like something beyond my skill lol...its an 85 Trans Am....thx guys
Old Oct 16, 2006 | 03:24 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
The horn relay is above the drivers right knee. Remove the panel above your shin. Then, look to your right from the steering column. There will be a panel with a white square relay above the buzzer box. Remove the buzzer box to access the horn relay. Plug and play. Hope that cures your horn problem.
Old Oct 16, 2006 | 03:27 PM
Ok wicked dude thanks a lot your a big help!!!...don't know how long I've been trying to figure out where it is lol
Old Oct 17, 2006 | 06:54 AM
Wadebryant's Avatar
Another common horn problem area is the horn ring and contact under the horn button on the steering wheel. If the relay replacement doesnt get your horn honking, pop the horn trim ring off and look for broken or missing parts there. Sometimes the spring under the contact ring fails or the contact is not completing the circuit.... just eliminate one thing at a time.
If you havent already, order or pick up a Haynes repair manual for your car. They're cheap and a fairly good source for common repair items. I've worn mine thin.
Good luck
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
