TPI to carb swap.. wiring issue
Old Oct 18, 2006 | 01:51 AM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Ok so I've read through threads pertaining to the this subject but I'm seeing that a lot of people have been able to remove the ECU wiring harness without touching the stuff coming from under driver side dash (gauges/ignition/starter stuff). I don't know, but does this only work for certain year thirdgens? I have a 90, a speed density setup. I'm in the process of removing the wiring but noticed that the starter wiring (3 red wires, 1 purple) do not come directly from the under dash wiring. I noticed that 2 of the 3 red wires(2 wires that come together for 1 connection that goes to the positive post on starter) go to some connector which in turn comes from the ECU harness. Then theres a lone red wire, which goes to a small connector that goes to ECU harness.
By removing the harness, would require removing those. So what would I do in that kinda situation? Any help/input would be appreciated.
Old Oct 19, 2006 | 02:04 AM
Firebat's Avatar
Might have more luck asking in the engine swap or carb forums. Wouldn't hurt anyways...
Old Oct 19, 2006 | 08:07 AM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
Hey
I just recently turned a trans am from TPI to carb. The thing i did was get rid of your main harness thats on the passanger side that hooks to your computer. Then the harness on the drivers side that plugs into the firewall (which is next to your headlight harness), take it out and get a older harness like from a 86 or older iroc or z28 or maybe berlinetta? ....tpi or carb...dont matter i dont think. It will have your starter wires, alternator wires, and temp guage wires. i may have one sittin around...have to check.
Old Oct 19, 2006 | 04:43 PM
Engine: 355 TPI
I think I'll have to do that. If you have one, let me know, I'm going to start looking around.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
stalkier
Aug 7, 2015 04:49 AM
