Short in the alternator?
Old Oct 28, 2006 | 12:57 PM
ULTM8Z's Avatar
I chased down a apparent short circuit to the alternator. It's a CS130.
Here's the scoop, I disconnected the negative battey cable and put a light bulb from the cable to the negative battery terminal. With all interior lights out, radio clock disconnected, engine computer disconnected, the light was still on. I ended up pulling the plug off the back of the alternator and bingo, the light goes out.
Narrowing it down further, I found that the short is on the F terminal. If connect a single wire from the F terminal on the plug to the F terminal in the alternator socket, the light bulb goes back on.
Is this really a problem (before I yank it off and take it down to be tested)?
EDIT: I just noticed something else. As I connect/disconnect the plug to see the light going off and on, I can hear a very faint, but very high-pitched noise coming from the alternator. I have to put my ear pretty close to hear it. But it's definitely audible.
Old Oct 28, 2006 | 04:29 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
sounds like the diodes are bad. depending on how bad it is, that will drain your battery in anywhere from a few days to an hour or two.
with everything turned off & plugged in there should be no sounds from the alternator.
Old Dec 30, 2006 | 01:23 PM
SpeedJunkie's Avatar
Car: 88 IROC
I have this exact problem with my 88 tpi 305. Now I purchased a brand new alt and it still is showing a draw with the plug in and it makes the same sound. Im trying to trace the brown/white wire from the alt plug which seems to always have power, maybe making a ground in the alt? The wiring diagram says this wire goes to the fan fuse in the box, pulling this does nothing for me. Still a drain.
Any help?
Old Dec 30, 2006 | 04:49 PM
ULTM8Z's Avatar
I dont' know. I replaced my alternator and problem solved.
apie2546
Oct 16, 2016 02:24 PM
skinny z
Oct 5, 2015 06:23 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
