ac wiring 1986 bird
Old Oct 29, 2006 | 08:29 AM
slipshift's Avatar
Car: 1986 trans am
Engine: 350 600 edelbrock
Transmission: 700 r4
ac wiring 1986 bird
Have just completed 305 to 350 engine swap in a TA 1986. Do I need to wire anything different for the A/C since i no longer use the ECM ? Now running carb that is not comp controlled with HEI.
Old Oct 29, 2006 | 05:33 PM
Jza's Avatar
Jza
Not really. There was an AC Pressure Switch that would tell the ECM to raise the idle a bit when the compressor turns on. That was to keep the additional load from bogging the car down or killing it.
Carbs accomplish the same thing with a (I forget the exact name, so I shall call it the) "A/C idle kickup solenoid". lol. It's basically a solenoid that will extend and push the throttle blades open a slight amount to raise the throttle when the AC turns on.
aaron7
Aug 17, 2016 06:02 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Pilotrick50
Sep 2, 2015 12:48 PM
bdads
Aug 24, 2015 06:01 PM
Catcher55
Aug 15, 2015 07:08 PM
