Battery Backup
Old Oct 30, 2006 | 11:40 AM
Truckin1999's Avatar
Battery Backup
I have moved the battery to the spare tire location. I have shaved door handles, and I was thinking about adding a second battery for a backup. I was going to mount a motorcycle battery next to the main battery to be used solely for the door poppers (if the main goes dead). My questions is, can I wire the grounds of the 2 batteries together, and run a switch and a relay between the positive cables? Therefore I would be able to flip a switch while the car is running and connect the two batteries to charge the motorcycle battery.
What do you guys think? Will this work or should I figure something else out?
Thanks,
-Sean-
-Crushed Blue Steel-
Old Oct 30, 2006 | 11:48 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Connect the grounds to the chassis. Connect the main battery as you normally would. Get a battery isolator for the spare battery.
Problem solved.
Old Oct 30, 2006 | 03:39 PM
Well the second battery is only going to be a small motorcycle battery so I don't know if the isolator will work. Plus that is an extra $70-80.
Old Oct 31, 2006 | 10:50 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
The isolator would work for any size battery but could be considered overkill in this application. The kind of hookup & relay you mention is ok. I would have controlled the relay with an oil pressure switch or something that connects when the engine is running, just for ease of use. I would then use two diodes, one from each battery, to supply the door popper circuit. That way you would get your doors open no matter which battery happened to fail.
Old Oct 31, 2006 | 11:20 AM
Car: 86 T/A
Engine: HSR 355
Oil pressure, tach input, voltage sensing, all are possibilities for triggering the relay for the auxilary battery. Two diodes to the door popper would definitely work and be affordable- I just thought of that as a thing that if someone has to ask then it may be out of their ability to assemble.
Old Oct 31, 2006 | 03:18 PM
I know some about electrical, I have already eliminated the ignition switch, and have everything operating on switches. Someone thought it would be cool to steal my keys and GM for whatever reason didn't have the right info to make a new key for me.
My next wiring project is to eliminate all wiring I don't need for engine and interior and fix the crappy harness. Should be a headache. I have eliminated the heat/ac and smog from the engine, and all wires have to be hiddin somewhere in the frame or fenders.
Thanks for the input guys! That helped a lot.
Old Nov 1, 2006 | 09:35 AM
Car: 86 T/A
Engine: HSR 355
I'm not sure how yours is wired exactly- just remember that the wireless reciever, the solenoids/relays, and the poppers themselves ALL have to be wired to the auxilary battery.
Old Nov 2, 2006 | 06:44 PM
I forgot about that for a minute. Maybe I won't even bother since you can still open the rear hatch with a key even if the battery is dead. I appreciate the help though guys.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
