CHARGING PROBLEMS
Old Nov 5, 2006 | 09:31 PM
MY84CAMARO06's Avatar
Car: 1984 CAMARO
Engine: 305 H.O Z28
Transmission: 5 SPD
Axle/Gears: DONT KNOW MUCH ABOUT CAMAROS
CHARGING PROBLEMS
I BOUGHT A NEW BATTERY,ALTENATOR BELT AND MADE SURE THE BELT WAS PROPERLY TIGHTEND.I PULLED THE BATTERY CABLES OFF WELL IT WAS RUNNING RAN AND DID NOT DIE.IM STUCK. SOME ONE TOLD ME TO CHECK THE VOLTAGE REGULATOR.NO IDEA WHERE IT IS LOCATED.I HAVE AN 84 CAMARO WITH A 305 H.0.5 SPEEED.PLEASE HELP ME..
THANKS
Old Nov 5, 2006 | 10:27 PM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
Well I have ta ask just xactly whats the issue?Also have ya installed a buncha aftermarket stuff like amp foglights ect??
Old Nov 16, 2006 | 05:47 PM
jkemp's Avatar
I have the same issue with my 84 trans am. Did you find a solution?
Old Nov 17, 2006 | 01:14 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Well, we have to ask again exactly what kind of symptoms are causing you to think you have charging problems?
Because the generator obviously works since the engine still runs when you pull the battery cable..
Old Nov 18, 2006 | 01:16 AM
Car: 1984 CAMARO
Engine: 305 H.O Z28
Transmission: 5 SPD
yes,you take the white wire off the altenator.and run it to the battery.i hooked my up to a toggle switch inside the car...the wire your bypassing comes from the ignition i think,,but it works
Old Nov 19, 2006 | 09:42 AM
jkemp's Avatar
I don't have a white wire. I have:
red from the positive alternator terminal to the pos. battery terminal.
red from the positive alternator terminal to a clip on top of the alternator.
Black from the clip on the alternator and into a wire harness that I goes to I assume a control to regulate the alternator. Is this your white wire?
I have had the alternator tested. On the car, it is not supplying power to the battery. On the bench, it tests perfect. This indicates a wiring problem. I tested the red wire from the alternator to the battery and it will pass current. It does however, have a line that comes off it. It is red and connects to a line that goes back into the car body. I assume it is power to something but it could be a control if th econnection is a switch?
Old Nov 19, 2006 | 12:00 PM
Car: 1984 CAMARO
Engine: 305 H.O Z28
Transmission: 5 SPD
yes my wire was white that came off the altenator clip.i ran it to a toggle switch aint had no problems since..i even get a better charge.get the toggle switch w/ out led light.just get a 30 or 20 amp with only 2 connectors..yea the wire to the right is the power.my clip plugs into the top of the alt.and the wire sits on the right!
one is power and the other hooks up to the post on the side of the altenator.and the other wire that hooks to the post is the ground so the other wire on the top with the clip that does not run to the side of the altenator is the wire
Last edited by MY84CAMARO06; Nov 19, 2006 at 12:02 PM. Reason: Automerged Doublepost
Old Nov 19, 2006 | 02:11 PM
jkemp's Avatar
why the toggle switch? when do you switch on / off?
Old Nov 19, 2006 | 07:30 PM
Car: 1984 CAMARO
Engine: 305 H.O Z28
Transmission: 5 SPD
right before you start it turn it on then right after you shut it off then turn the switch off..it works goodi get a better charge
jkemp's Avatar
scratch my last post. I found some schematics and that does go to the ignition and then to a light. It isn't required. Open or closed it doesn't solve my problem.
thanks,
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Slush92RS
Sep 2, 2015 08:56 PM
greenyone
Sep 2, 2015 03:39 PM
