Third Break Light Not Working Help Please
Old Nov 12, 2006 | 05:53 PM
cbdub405's Avatar
Car: 1989 Chevy Camaro RS
Engine: 305 V8
Transmission: Automatic
I have a 1989 Chevy Camaro RS...
The problem i'm having is my third breal light is not working i changed all the bulbs in it also cuz 2 dat was in there was burned out i seen so i but 5 new ones in there and still not working.....
I'm thanking that i may have to get the whole new break light part now just tryin to see what info sumbody in here can give me...
But i may go get a whole new break light if i cant get it to working....
Old Nov 12, 2006 | 08:34 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I just redid the one on my 89 RS. The connector itself (inside the spoiler) failed to get any voltage to the light assembly. I picked up another at a local junkyard for free and spliced it into the present harness. You might also check the contacts by your hatch pulldown to make sure they are clean - there are 2 brass "pins" on the botttom side of the hatch and 4 brass contact "plates" by the latch assembly, the 2 outside ones are used by the brake light.
Old Nov 15, 2006 | 08:36 PM
cbdub405's Avatar
Engine: 305 V8
Thanks i'm going to pick one up when i get up this thursday....
Old Nov 15, 2006 | 09:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
just check to see if the two electrical connectors coming from behind each rear seat and connecting to the lift struts are connected.
Old Nov 15, 2006 | 10:50 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
If your third light is in the spoiler then the connections are through contacts at the hatch pull down motor area. I had the same problem with my 89 RS. One of the conacts was broken but i jury rigged to work.
Old Nov 19, 2006 | 10:06 AM
cbdub405's Avatar
Engine: 305 V8
Thanks yea it was the whole light dats was messed up so i went and got one for $48.00 and hooked it up the other day now it works just fine,i guess the connectors was bad...
But i got it all working fine now thanks for everybodies help....
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
