Curise control switch disassembly?
Old Nov 23, 2006 | 03:04 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Hi,
I have diagnosed my intermitent cruise control switch problem(89 formula 350 tpi) to being loose connections within the head of the multi-function switch itself. If I pull and twist the wires exiting the multi-function switch before entering the steering column, applying force only to the wires coming from the switch--cruise control works.
I pulled the multi-function switch, but cannot disassemble further. I would like to try. I suspect that I just need to re-solder or recrimp the final connections inside the body of the switch.
Does anyone know how to take one apart without destrying the switch?
best regards,
-Brent
Old Nov 24, 2006 | 12:56 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I dont know for certain,but i think that it cant be disassembled at the point your
describing.My wires were severed where they exit the head of switch and i could'nt see any way of getting into it,so i replaced it.Someone in the US makes a aftermarket one (not GM ),that is a lot cheaper than the GM one,and is identical.Not sure who it is,but a search might help.
Alicat.
Old Nov 28, 2006 | 07:50 AM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
A1 auto makes on, but stay away from those. Mine fell apart in a year. I got a new GM part on ebay for $60 shipped.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
TBRays98
Sep 6, 2015 05:05 PM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
