Headlamp Not Working
Old Nov 24, 2006 | 06:26 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Its been awhile since I've been here :-)
Whenever I switch my high beams on, my drivers side low beam light goes out. The passenger side stays on (normal). When my high beams are off, both low beams operate.
Since I can't find my ol' Chilton Manual I was hoping someone could tell me where to locate the relay so I can replace it.
Thanks!
Old Nov 26, 2006 | 07:42 AM
Pukka's Avatar
Never mind,
The headlamps all run in serial from the switch, there is no relay. Apparently one of my low beams only wanted to work on one side and not the other...pretty strange. Replaced all four bulbs and everything is good.
Old Nov 26, 2006 | 11:53 PM
Jza's Avatar
Jza
The high-beam filament in the driver's side low-beam lamp was out.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
