Pictures (200kb total) of my fan switch, cant figure out how to plug it in?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Im connecting the fan switch for the first time since i've owned the car. Below is a picture of it. The plug is hanging right next to it, but I dont know how to plug it in. The plug just doesnt seem to fit into the switch. The plug (GRN/WHT wire) is all metal, about an inch long, and has two tiny prongs on the end of it. The switch just doesnt look like it was designed to 'recieve' the plug.
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
hey darkshot, if i knew how to post pics i would just show you,but that looks to me to be the right conn.,its just missing the plastic housing around it that connects to the sensor.If you look to the right of this screen,click on TPI PARTS,then click on catalog,then on engine wiring,scroll to bottom of that page,and on the right hand side you will see what that conn. is supposed to look like.Hope that helps,the metal part of your pic goes into the center of the switch.Good luck,timmy
eightsixseven
Dec 16, 2024 01:50 PM
