Battery dies after a few days...???
Old Dec 21, 2006 | 10:42 AM
Joker1232's Avatar
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
So as the title says about every 3 days i will go to work on my 92 z-28 and the battery is dead. Its a new battery, last one died. No interior lights are on, i have kept the alarm off. Not sure what it could be. A ground or something is staying on. Any common problems out there????? Only things i can think of are that that hatch button doesnt work and the horn doesnt work as well. Havent go to fixing them yet, could there be a short or somethin there? Its a slow drain on the battery so I am up for any ideas on how to look for it. Its not a daily driver but i hate jumping it to take it out on the weekends.
Old Dec 21, 2006 | 01:26 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Fairly simple way to start looking for an electrical system drain.
Remove the negative battery cable and put one test light lead on the disconnected cable & the other lead on the negative battery terminal. The light coming on will indicate a drain - remember, you must have all switches turned off. If you open the door the test light will show a drain - trying to turn on the dome. If you see the test light lit up, then you can remove each fuse 1 by 1 to narrow your search to the circuit. Once you isolate the circuit, look for easy things before tearing harnesses apart.
Good Luck,
Corky
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
