i have a REALLY wierd short in my 86 camaro
Old Dec 23, 2006 | 07:37 PM
blklblsk8r16's Avatar
i had a short in my car about 4 months ago that made all of my lights flash and my raqdio flash on and off. Also any time i turned my wheel to the right my battery guage wouold drop down then when i turn to the right it would go back up. well i looked around and found that my radio wires were stripped and shorting out. well here we are for months later and the problem is back.... but this time everything is the same except when i turn to the right not only does my battery guage drop but my temp guage goes up until i turn left then it goes back down. thnx in advance and sorry so long.
Old Dec 23, 2006 | 09:26 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
??????????????? Maybe the power leads from the starter are getting smashed by your steering linkage where they run under the front of the motor.
Old Dec 24, 2006 | 10:32 PM
i checked that but the main wire from the battery runs over the linkage and the other two wires run straight up the side of the motor.
Old Dec 26, 2006 | 01:31 AM
jayswny's Avatar
my battery cable was melted a little from heat off the ex- manifold just enough that when i turned it would bump up against the motor causing this to happen. I would check the alt wiring too.
Old Dec 27, 2006 | 04:45 PM
i checked both of those wires and didnt find any problems but replaced them anyways... it didnt do the trick i still have the short. i have noticed that i think there is either a seperate short or the same one acting in a different way. now not only does that happen when i turn but when i use something that draws power i.e. headlight, fog lights heater... by radio cuts off for a sec then back on. it alsop does this when i hit a bump. i hope someone can help cause me and everyone i know are lost. thnx.
Old Dec 27, 2006 | 09:15 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
A few Questions...
Is the car moving when you experience the left and right had turn issue?
Is the steering column loose?
Are the motor mounts ok?
The temp gauge going up is due to a short in the sender wire. It may be rubbing on the block or is somewhere between sender and the gauge.
It could also be a bad ignition switch. All the gauges go full sweep when you turn the key before cranking. A short in the steering column around the switch can cause these things and would be suspect due to the turning and the bumps.
The on off radio sounds like a circuit breaker tripping. Or the hot wire from the starter being grounded out.
Check for bad ignition switch, motor mounts, loose column, or bad ground from battery to chassi and block.
Old Dec 30, 2006 | 06:54 AM
most of the time the car is moving when i experience the left or right hand turn issues, but it will do it once in a while not moving. i have noticed that the car usually has to be in drive though.
no my steering column is tight except the custom steeing wheel itself. its kinda loose but there are no wires runnin up there.
motor mounts should be good...
i check the sender unit wire from the firewall down and it was fine... could it be shorting inside the dash?
the ignition switch makes since. but i have also notice that the ignition switch is run by a metal bar until it makes it to the area of my brake petal and then it turns into an electrical box. could this still cause that kinda prob?
one last thing you said look at the ground wire from battery to chassis and to block i have only seen a ground from battery to block and it might have some grease covering it. but where should the one to the chassis be?
Old Dec 31, 2006 | 07:13 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
The ground from the battery to the chassis, on my car atleast, isn't too hard to find, it runs from the neg. terminal of the battery to the body 6" away.
Old Dec 31, 2006 | 10:29 PM
I FOUND IT!!!!! thanks everyone. i was missing my ground straps from the engine and tranny goin to the chassis. thanks for the help!
evilstuie
Feb 28, 2016 03:33 PM
camaro71633
Sep 1, 2015 10:24 AM
perZ
Aug 21, 2015 05:51 PM
Bryan F
Aug 18, 2015 02:28 PM
