cranks, but won't start
Old Dec 29, 2006 | 04:30 PM
83Z88ROC's Avatar
OK here we go. I picked up an 89 RS w/2.8L a while back. The car will crank all day long but won't start. I've got good fuel pressure, but the injectors don't seem to be firing. I've got power to the coil, but no spark from it. I've replaced the ignition module, the coil, and even tried a different ECM (out of an 1987 w/2.8L). I'm also not getting any error codes. I'd appreciate any help.
Old Dec 30, 2006 | 05:50 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
the module has that grease on the bottom of it right?
Old Dec 31, 2006 | 09:53 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Is the check engine light on like its supposed to be when you turn the key to run without starting? No power to the ECM would explain your symptoms (blown fuse would be nice to fix).
Did you check the injectors with a noid light ($5) to verify they arn't getting power?
I can't remeber if that engine has a crank position sensor. If it does and went bad it would prevent spark and injector pulses.
Just guessing if you haven't noticed.
Old Dec 31, 2006 | 02:07 PM
83Z88ROC's Avatar
Yes the module has the grease under it, is this real critical? The check engine light comes on like it's suppose to and it doesn't flash like the book says it will if there is an issue with vats system. The injectors firing we checked with the ole stethoscope method, (it worked on my iroc(?) just listen for the clicks. As far as the crank sensor...I'm not sure, I thought the engines with crank sensors didn't have distributors (?). Can you tell me where would it be ? Thanks for the replies, at this point we'll try anything !!!
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Winchester1094
Aug 18, 2015 10:23 AM
