Strange running and turn signal light problem!
Old Dec 30, 2006 | 10:28 PM
camarodubs's Avatar
Car: 1987 camaro
Engine: gm goodwrench crate 350 mild
Axle/Gears: 28 spline 7.625 10 bolt w/273
I am having a problem with my running lights and turnsignals. The tail light fuse is blowing when I pull out the headlight ****, and when I try to use the turn signal the bulb stays on and the running lights come on. I have searched every inch of wire from tail lights to the header panel and still havent found a short or anything. could some please point me in the right direction I would appreciate it.
Old Dec 31, 2006 | 12:10 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Sounds like you've either got a bad bulb or a bad light socket or both. Put a test light across the tail light fuse - light on = short to ground. With test light still in place go on the hunt for dead short (light will go out when found). It also sounds like you've got a ground problem - signal lights on - grabbing a ground through the running lights keeping signal lights on & dimly illuminating running lights.
Keep in mind this problem can all be cased by 1 bad bulb or socket.
Good Luck,
Corky
Jae992
Aug 27, 2015 09:07 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
