getting rid of vats and the key
Old Jan 1, 2007 | 01:32 PM
jerryman762005's Avatar
Car: 89 camero rs
Engine: v6
Transmission: automatic
i have an 89 camero RS and would like to get rid of the whole vats system including replacing the ignition and all . Can anyone help me out
Old Jan 1, 2007 | 09:07 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
if it has starter disable, you will need to bypass that with some wiring work.
to find out how to get around the stater disable relay you can use the wiring diagram about half way down the page here,
https://www.thirdgen.org/vats_passkey_system
there are 2 ways around for fuel enable.
first is to burn a prom with VATS turned off, if you can't do that then you need one of these,
http://www.painlessperformance.com/w...rchField=64023
Gunner242
Dec 25, 2015 04:49 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
