changing/setting ECM/PROM???
Old Jan 3, 2007 | 12:19 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Who can i bring my ecm/prom to have it changed to my new specifications. Like adding performance parts and wanting to change the fan switch temperature???
Old Jan 3, 2007 | 05:24 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
There are several vendors that will do if for you, but.... They will charge you more then it will cost to buy the equipment to do it yourself.. Plus, changing the fan temperature takes about 3 seconds, and you have the ability to keep learning as you go.
Old Jan 3, 2007 | 06:24 PM
Bobby_80s's Avatar
Axle/Gears: no idea
Ok thanks, any idea what kind of equipment or what is the easiest way to access the ECM?
Old Jan 3, 2007 | 10:35 PM
Toehead's Avatar
https://www.thirdgen.org/forums/diy-...uide-book.html
You will need some software to edit the bins.. I use tunerpro rt.
You will also need either an aldl cable and chip burner, or an ostrich. The ostrich is a realtime chip emulator that replaces the stock chip and interfaces via usb. You can read all about it at that link.
ffvetteman
Jan 31, 2012 08:17 AM
mattyc
Sep 13, 2010 09:50 PM
inittab
Jun 7, 2009 07:14 PM
CCrockett86
Jan 17, 2009 08:06 PM
v8nate92RS
Sep 13, 2004 09:51 PM
