Relay Connectors
Old Jan 8, 2007 | 09:27 AM
slowdeath's Avatar
Relay Connectors
Anyone know who sells the relay connectors for an 87 IROC? startin to get real frusterated workin with these things cuz theyre so beat to ****. spent all day doin the wiring for my MAF cuz i was gettin a code 36, so i go to start the car and my fuel pump is dead, hooray. I apparently need to put brand new connectors in there so i dont hafta HOPE nothin jiggles loose while drivin. Gonna hafta borrow a car for work for a few so hopefully ill have some links or somethin to check when i come back, thnx guys
Old Jan 8, 2007 | 09:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
do 87s use the "weatherpack like" relays that the late cars have (like my 91/92) or the earlier ones??
Old Jan 8, 2007 | 03:01 PM
slowdeath's Avatar
ionno, dont think so, my relays are hard plastic squares, and the connectors are just hard black plastic too. so guess not
Old Jan 8, 2007 | 06:16 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
relay connectors
Been there before slowdeath I had same problem with my old car(87 IROC) it was very frustating.This was before I found TGO as well.All of my relays on the firewall had loose connections&bare wires about 1" past the relays.2 years ago I would have told you to use a small screwdriver &pop out each term. &heat shrink it then pop it back in.But today I would say,Try TPI parts.They have an advertisement on this site on the home page,I have bought a few things from them on my current project&they have been very knowledgeable &helpful.Thats all I know&good luck.oh yeah,forgot to add that make sure you have something like gas or thinner around to clean up your hands cuz there is some nasty black stuff in each of the relay terminals that doesn't come off with soap or hand cleaner alone
Last edited by TIMMYS89GTA; Jan 8, 2007 at 06:23 PM. Reason: forgot to add something
Old Jan 8, 2007 | 10:42 PM
slowdeath's Avatar
thnx a lot bud, ill definately check them out. and ya ive been pokin around in there long enough to know about all that gunk in there, lol.
BumpaD82
Feb 26, 2016 02:57 PM
327IROC85
Sep 23, 2015 12:11 AM
gta892000
Sep 16, 2015 12:37 AM
Roxtar69
Sep 15, 2015 05:24 PM
