VATS QUESTION
Old Jan 9, 2007 | 10:10 AM
tpi88camaro's Avatar
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
VATS QUESTION
I have just completed swapping an 89 GTA dash and wiring harness into my 88 IROC. Since my car did not have vats from the factory, am I to assume it is basically disabled in the ecm? No 5v ref from the vats module for the injectors needed? If so, all I should have to do to get the car to fire up and run is connect the large yellow and the GRN-WHT wires at the starter enable relay right.
Old Jan 9, 2007 | 07:18 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
did you use the ECM from the 89?
Old Jan 9, 2007 | 09:43 PM
Car: 1980 Regal
No, I am using the one out of my IROC since it did not have vats and I know it is good.
Old Jan 9, 2007 | 11:46 PM
DENN_SHAH's Avatar
with the fix done at the starter disable relay i think you should be good to go then.
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
