Automatic Shifter Plate Light?
Old Jan 13, 2007 | 09:04 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Ok, I need to know EXACTLY what powers this little light.....
I have been trying to figure out why this....along with my HVAC lights, and my long gone factory radio display wont come on anymore since I put in a newly charged battery...
I have been trying my best over a year now to figure out what got fried from that battery.
I have already replaced these parts:
Replaced It, Doesnt Fix Anything...
Again, This Fixed NOTHING....
I have checked all fuses, they are all good, The bulb itself for the shifter plate has been replaced..
I dont know what to do, i pray to god its not a fried wire, because Im SOL if thats the case.
Any suggestions on why my little light wont come on anymore?
Old Jan 14, 2007 | 08:19 AM
Mitre#136's Avatar
Car: 88 Pontiac Trans Am
Engine: 5.0L
Transmission: 4spd auto model unknown
It sounds like replacing the battery caused a fusible link to blow, it would probably be a matter of tracing wires to see if you can find it, otherwise check your hayes, or chilton manual for wiring diagrams. In a worse case scenario, you would have to look at your headlight switch, check and try to trace the wire that goes to the affected lights, then if you cant find the fusible link, tap a wire into the parking light circuit and run to the dash and console for those little light bulbs. Good luck bro!!!
Old Jan 14, 2007 | 08:29 AM
firstfirebird's Avatar
Are your dash lights out too?
Old Jan 14, 2007 | 06:48 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
No, they light up like they should, and dim smoothly with the wheel
Old Jan 14, 2007 | 07:05 PM
Then I'd guess fusable link...
Old Jan 15, 2007 | 02:04 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
i think those are run in a curcuit might check the connection on the dash lights to see were the curcuit breaks
Old Jan 15, 2007 | 05:08 PM
That's why I asked, I've tracked down that circuit before and posted a thread on how to fix it if it were the led's in the fog/hatch switches.
Click here to see...
Old Jan 16, 2007 | 07:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I know it has been a while since I responded to your post regarding this problem. However may I suggest that you check the gray wire leading off the back of the "INST LPS" fuse. This wire powers all the lights that you have mentioned. Also check the "INST LPS" fuse.
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
camaro11j
Sep 19, 2018 08:49 AM
NBrehm
Aug 25, 2015 11:49 PM
Omega
Aug 10, 2015 12:46 PM
