PASS KEY
Old Jan 15, 2007 | 10:02 AM
SLONOMO91RS's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
PASS KEY
I have a 91 rs 305 tbi, and I cant get it to run. I pulled the codes and got 22 and 53, what is code 53? How can I fix the problem and get my car running again?
Old Jan 15, 2007 | 09:04 PM
truegmman's Avatar
Car: 86 Iroc Z/89 Firebird Formula
Engine: 355/305tpi
code 53 indacates a problem with the security system most likely the vats is the car doing anything
Old Jan 15, 2007 | 10:21 PM
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
If I prime the car it will start but it will die in 2 seconds, I can keep it running if I peddle it, but I cant hold it steady or let it idel or the injectors stop spraying.
Old Jan 16, 2007 | 12:45 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
diagnostics for code 53
to view these, open them in windows picture & fax viewer, you may need to save them to your computer to do it.
these may also help,
https://www.thirdgen.org/vats
https://www.thirdgen.org/vats_passkey_system
also, check your fuel pressure, it should be 9 ~ 13 PSI.
Attached Thumbnails PASS KEY-code-53.gif   PASS KEY-code-53a.gif   PASS KEY-code-53b.gif
Old Jan 16, 2007 | 07:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
In addition to the above, your code 22 is a low voltage to the throttle position senson.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
darwinprice
17
Oct 11, 2015 11:51 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
