HELP! with 1989 Iroc VATS system
I have a 1989 Iroc I just got the car and it did not have a stering colum so I put one in but car will not start.....after doing alittle reading up an 89 Iroc I found out that some come with the VATS system does any one know how to tell if the car has a VATS system in it??? If so how do I find out what chip I need for it to run in the key #1-15? is there a way to check the vin # or.......do something else to find out? I could use some help with this so I can get her up and running
Thanks for looking
Thanks for looking
Car: 91 Z28
Axle/Gears: Stock
This should get you started:
https://www.thirdgen.org/vats
https://www.thirdgen.org/vats_passkey_system
You can also search the forums for "VATS bypass", there are several articles on different methods of bypassing it.
Thanks,
but I do not have the key that has the chip I was wondering if someone know how to find out form the vin# or something like that could tell me if it was a VATS car and if so what chip 1-15 did I need
First, you need a new ignition cylinder with VATS wiring on it. It should have a white wire and an orange wire on it. The cylinder will come with dummy keys with the proper cut pattern. You will need to locate the VATS ignition wiring harness and hook up the new ignition, then you'll have to get a locksmith with a PassKey or VATS Interagator. He'll put the dummy key in it and then he can tell you what resistor number you need to cut the new key with.
Car: 91 Z28
Axle/Gears: Stock
My 91z wont even try to crank...we replaced the ignition switch...and Im positive I had VATS disabled on the PROM chip I bought from TPIParts..
And we have voltage all the way to the blk/yel wire going into the PassKey module. But still cant verify if we have voltage to the starter enable relay, because we cant find it
Car: 1999 subaru forester GT (urgh)
Engine: ej20 turbo
Transmission: 5speed
Axle/Gears: 4.11:1 awd
I just got in touch with GM, and they didn't even have the code for my '89 IROC (I wanna spare key or three), and the way they kept records back then, the chick said she couldn't trace it, even with the VIN i gave her.
Try getting in touch with GM, or a dealer, and they might be able to chase that up with the VIN...
Cheers
Cheers
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
[QUOTE=lizardkng;3196274]But what about bypassing the passkey system?
[/QUOTE
On our cars the VATS and the Passkey are the same or rather there is no passkey system only VATS. If they truely disabled VATS in the prom then you have another problem. Chances are they didn't disable it.
[/QUOTEOn our cars the VATS and the Passkey are the same or rather there is no passkey system only VATS. If they truely disabled VATS in the prom then you have another problem. Chances are they didn't disable it.
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
lizardkng, the VATS system on Fbodies does two basic things to avoid theft. The first is in the prom, where the ECM will not fire the injectors without a VATS signal. The second is that the VATS module controls a starter enable relay so the engine will not crank.
Disabling VATS from the prom will allow the injectors to fire, but you still need to rearrange the wiring going to the starter enable relay. The starter enable relay is located behind the driver side kick panel. You need to bypass the relay so the engine will crank without relying on the VATS module. To do this, splice together the wire running to the relay from the ignition switch (will have power when the key is in the crank position), and the wire at the relay which goes to the starter solenoid.
If you have any questions, feel free to contact us.
Car: 91 Z28
Axle/Gears: Stock
Nice!
TPIParts people.
Right now, I cant find my invoice, so I dont know my order date...I had sent an email to you last week to find out what info I needed in order to verify from you that my VATS is in fact disabled, as I am positive I requested. Cant find my invoice, so I dunno my order date.
And whats this about no PassKey system, only VATS? The black plastic box I pulled from under the dash on the passenger side clearly says "Delco Electronics PassKey Module".
TPIParts people.
Former Sponsor
Car: 1992 Camaro RS
Do you remember more or less when you ordered it? If you can't, PM or email me the name you placed the order under and I'll look up the specs we have on file for you.
Car: 91 Z28
Axle/Gears: Stock
I *think* I bought it from TPI parts...the box I got it in is at the shop so I cant verify...it was either TPI Parts or TPI Chips...I just cant remember off the top of my head...and cant access the box right now...
Thanks for your help.
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
yes it does and it stays on
If you have 48 minutes a trip to radio shack will get your car started....
Follow the VATS troubleshooting, except you'll try all 16 resistances, waiting 3 minutes between each attempt.
Re: HELP! with 1989 Iroc VATS system
If thats still the case that the security light stays on, then VATS is still active.
4 minutes
Transmission: World Class T-5
Axle/Gears: BW 3.45
Car: 1989 IROC-Z
Engine: L98 350 TPI
I looked but I don't have a picture of it. VATS delete on the prom removes the need to send a square wave to it. The starter enable relay is on a separate circuit. You bypass it the same way you bypass any relay; find the 2 wires that are connected when the relay is energized, and jump those with a short wire that has male spade connectors on each end. They will probably be the thick ones. Make sure your jumper wire is the same gauge.
Car: 1989 Chevy Camaro
Engine: 6.2 376l LS3
Transmission: 4L80E 3k stall
How I did mine was if your still using stock motor the wires under the steering column you put resistors to the wires matching the resistor on your key this will let the injectors fire up, 2nd you have to ground the starter enable relay located on the driver side behind the kick panel, Relay will have 2 big yellow wires 1 thin green wire and 1 big green wire this will be the started enable relay. If you ground the small green wire when you turn the key you should here it click and it will crank, you can ground this wire to say to a secret push button to kind of still have the anti theft feature on the car or if you permanently want it to just crank over you connect the big yellow cable on the outside to the big green outside.
norcalz28
Mar 17, 2004 10:30 PM
