I think the car is haunted
Old Jan 22, 2007 | 01:45 PM
PDye's Avatar
Car: 1992 Camaro RS
Engine: 513 BBC
Transmission: 700R4 (ummm yeah stock)
Axle/Gears: Junkie ones....
Okay, did a BBC swap. Car started fine, didn't run great (bad fuel pump) but started turn key. Went out the other day put the key in, turned it and I got no "security" light (use the bypass resistor thing mentioned on this site, since I don't have a ECC anymore), the tach is bottomed out (below zero), and for some reason the dash lights are all screwed up. Meaning: the lights that light up the center portion of the dash (specifically the lights that light up the 140ish MPH marker) are on when I turn the key to the on position. If I turn the lights on those go out and the others come on. Anybody with any idea what the crap happened please let me know.
Thanks,
Phil
Old Jan 22, 2007 | 11:25 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Check your major grounds
Block to chassis
battery to block
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
