VSS/Speedo
Old Jan 24, 2007 | 05:41 AM
lonesomecrow's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
VSS/Speedo
I have a really weird problem with my speedo. I got my RS 25th Anniversary on October last year and the speedo hasnt been working since then, I tried replacing the VSS, but no success, I replaced the speedometer itself with a used one with no success either, i also tried checking all the wiring that goes from the VSS to the transducer and from the transducer to the cruise control module and it all seems to be OK. Do you guys have any idea of what is wrong?????
Old Jan 24, 2007 | 06:50 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
When you replaced the vss did you visually check the drive gear in the trans tail shaft? How did you select the replacement vss? Did you purchase the replacement from GM using the vin number? Did you use an ohm meter to check the vss wiring connections and ensure that you had continuity to the ecm? Has your speedo ever worked? Do you have any hacked wires in the harness?
Assuming that everything is as it should be, sometimes the wiring harness connection to the cluster can cause the no speedo condition.
Old Jan 25, 2007 | 01:54 PM
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
yeah i checked everything and it all seems normal and like it should be, but it still doesn't work, and i am out of patience!!!!!!
Old Jan 26, 2007 | 05:43 PM
Wadebryant's Avatar
You didnt answer the questions I asked in my first post.... How did you check your wiring, visually or with a test set? How did you obtain the correct vss?
There is a tech article on this site that might also help you. It's an article on swapping electrical Trans Am clusters but, it identifies the wires from the cluster to the speedo that you might want to check with a test set.
Point is, the circuit from the vss to the ecm must be good, likewise it must be good to the cluster. Assuming you have the correct vss, the ecm is okay, the drive gear is good and all wiring and the connections are good, the cluster is okay, it should work. Lastly, pull the cluster, clean the contacts and the male ends of the connector.
Good luck
JaybirdLSSU
Sep 2, 2011 07:39 PM
Lucid
Mar 7, 2009 07:36 AM
84redta
Nov 3, 2008 12:10 PM
