horn button
Old Jan 24, 2007 | 05:59 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
horn button
can some one tell me how the horn button works, does it use a ground ? ive looked at the diegram.
Old Jan 24, 2007 | 06:18 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
There is 1 wire coming up through the steering column If that wire touches ground the horn should go off. If it doesn't then you have a problem. The Horn button on the IROCS and probable the RSs also keeps this wire from ground with a spring loaded mechanism until pushed grounding and causing the horn to blow.
The button on my car was broken when I got the car but by drilling the plastic standoffs and tapping threads I was able to repair mine.
Old Jan 24, 2007 | 08:42 PM
jayk2k3's Avatar
Car: 85 camaro z28
thanks, that was the answer i was looking 4.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Veaceonee
Sep 29, 2016 08:15 PM
armac
Sep 29, 2015 07:06 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
sahlomonic
Sep 20, 2015 07:15 PM
