VATS BYPASS
Old Jan 30, 2007 | 01:59 PM
SLONOMO91RS's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
VATS BYPASS
If I wanted to bypass the vats where could I get the resisteors from? I tried getting the reading off the key but I dont know if it is right. What should the multimeter be set on to check it?
Old Jan 30, 2007 | 08:39 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Set it the lowest range on the OHMs scale, that gives you a reading other than OL(overload). If it doesn't give a good reading on one scale bump the scale up one.
Old Jan 31, 2007 | 06:49 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
http://tpiparts.net/vehicle_anti_theft_system__vats_/
If your key reads in one of these ranges you did it right.
Radio shack.... or you could buy a potentiometer (variable resistor) from radio shack and superglue it on the right setting.
Old Feb 1, 2007 | 08:21 AM
Car: 91 camaro rs
Engine: 305 tbi
Transmission: t-5
Axle/Gears: 3.08
Do I need to put resisters in both wires or just one?
Old Feb 21, 2007 | 04:01 PM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Axle/Gears: 273 pegleg
Tell me if I understand this procedure correctly. There is a two wire connector on the steering column that the VATS reads the resistance of the key through. All you need is to find the resistance of your key and jump the connector with the proper resistor and everythings fine? No problem with the computer seeing that the circuit is always made? Just bought a 89 RS and only got one key, and hate to get ripped for a hundred plus for an ignition key!!
Dave Berry
Old Feb 21, 2007 | 04:18 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I made a drawing of what you need to do.
junior419
Apr 7, 2025 11:35 AM
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
Racerx974
Sep 19, 2015 10:16 AM
