gauges quit while headlights are on
Old Jan 30, 2007 | 05:07 PM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
I have a 92 rs and I installed a 145 mph cluster from a z28. When im driving during the day everything works fine but when i turn the headlights on the left turn signal doesnt show that its on and the speedo sticks at the speed i was going when the lights turned on. this is quite a pain in the a**
Old Jan 30, 2007 | 05:13 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
Sounds like you might have a bad headlight ground.That's what I would check first.A bad ground can cause weird problems.
Old Jan 30, 2007 | 05:22 PM
Gramps's Avatar
Car: 87 Camaro IROC
its prob your new cluster, mayb your cluster has a little short in it, take it back out and reinstall the old one, see if the same problem arises.
Old Jan 30, 2007 | 10:05 PM
spina74's Avatar
Engine: 6.0, 305
if the cluster has a short in it how do i fix that?
Old Jan 30, 2007 | 10:31 PM
Gramps's Avatar
Car: 87 Camaro IROC
well a short in the cluster may be unfixable because it could be in the little circutry, what you can do is swap out parts from the bad cluster to the good cluster, like just switch out the speedo from the bad cluster and install it into the good cluster and your good to go. ive got 3 different clusters and one cluster has a short, so i just pulled the good gages from it and put it in another cluster that i know has no shorts.
Old Feb 13, 2007 | 04:49 PM
spina74's Avatar
Engine: 6.0, 305
ok i pulled out the new cluster and installed the old one...the guages do the same damn thing.......its quite annoying when u gotta keep turning off your lights to see how fast your going....does anyone know how to fix this....and i got 2 grounds behind the passenger cyl head off.....can they be causing the problem
Old Feb 14, 2007 | 02:09 AM
stelios_z28's Avatar
Car: 1982 FIREBIRD-1983 CAMARO
Engine: 305 LG4
Transmission: TH350-TH200
i had the same problem with you my friend.finally i found that the problem was in the fuse box under the dash.more specific...just change and reinstall the fuse that has the "gauges" identification.in my car when i push that specific fuse to the bottom end of the box..my gauges wont work...when i took it backwards...in a specific point the gauges work perfect!!!check it out!!
TrevinE
Sep 14, 2015 03:20 PM
Glowsock
Sep 6, 2015 06:40 AM
luvofjah
Sep 3, 2015 07:08 PM
andy74
Sep 3, 2015 08:41 AM
