Dropping Voltage at Idle
Old Jan 30, 2007 | 08:29 PM
SMKNTRS's Avatar
I think my Alt is taking a crap but im not sure. It drives fine at normal driving conditions but once i stop at a red light my lights dim and it runs slow. I think this is a pretty good indication that its not charging properly . To get it to act properly I just hold the brake while holding it at a steady rev and it stops acting up.
Old Jan 30, 2007 | 09:40 PM
Gramps's Avatar
Car: 87 Camaro IROC
did it ever do that before? you know, durring the day it shouldnt do it, your not running any accessories. but at night your running your lights, your heater, your rear defroster (biggest culprit) and your alternator sometimes cant keep up. its a common thing to see on all cars. what amperage is your alternator now?
alternators wont put out full power until like 2000rpm ne ways. mayb you can get a bigger alternator if your worried about it.
Old Jan 30, 2007 | 10:13 PM
SMKNTRS's Avatar
I've had the car for 5 years and its never done it before. I dont particularly remember if it did it during the day or not. its just most noticably at night of course because of the lights
Old Jan 30, 2007 | 10:28 PM
Gramps's Avatar
Car: 87 Camaro IROC
well it could be wearin out. it could even be the cable...if it really bothers you, replace the cable cuz its cheap compared to the alternator, and if your still bothered, replace the alternator with a 105amp alternator...a good qualtiy one too.
Old Jan 30, 2007 | 10:32 PM
gunner53227's Avatar
Car: 86 TRANS AM
Transmission: 700 R4
Axle/Gears: 10 bolt/3.73
I have the same problem. I rebuilt the alternator last year and even after that is was still doing the same thing, but not as bad. I also found a loose ground wire that was affecting it also. It still acts up. Sometimes it fine, but other times it still acts up from day to day.
Old Jan 31, 2007 | 07:09 AM
ezliving4ume's Avatar
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
question but u don't have underdrive pulley's by chance?
Old Jan 31, 2007 | 08:16 AM
SMKNTRS's Avatar
Its the original alternator so im hopin its just wearing and i just have stock pulleys. Maybe my battery just isn't charging correctly ? ill check my wires out in the meantime.
Old Jan 31, 2007 | 11:08 AM
Car: 86 TRANS AM
I have stock pullies.
Old Jan 31, 2007 | 06:45 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
How old is your battery? Just as an alternator wears over time (brushes wear down eventually leading to low current output), a battery can wear out too. Figure 2-3 years on a battery (depending on brand) - less if your in a cold part of the world.
Old Mar 10, 2007 | 08:58 PM
SMKNTRS's Avatar
I put a new battery, new terminal bolts and still got the same thing. A diode in the alt is prolly going bad.. oh well.
Old Mar 14, 2007 | 07:51 PM
SMKNTRS's Avatar
could it be a voltage regulator?
Old Mar 15, 2007 | 12:47 PM
Car: 86 TRANS AM
When I rebuilt my alternator, i replaced my regulator and it seemed to help a bit, but it still acts up.
Old Mar 15, 2007 | 03:06 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Check the fusible link that runs from the alt to the battery.This just happened to me.I had to replace the line with a 30A inline fuse.
Old Mar 25, 2007 | 12:44 AM
paulyz's Avatar
Re: Dropping Voltage at Idle
does this loose ground or missing ground wire show up as a voltage loss all the time? I'm having the same problem under a load, the alt. checks ok
Old Mar 25, 2007 | 05:40 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
The alt. wouldn't be responsible for making the engine run slow.. How much slower does it run at idle? A high load on the alt. could perhaps make it drop 50-100 rpm, but then something should be getting hot.. I had this happen once but it was the battery, and it got hot.. I don't think a shorted diode would constitute a load on the engine..
Old Mar 26, 2007 | 06:32 AM
SMKNTRS's Avatar
well the engine isnt really running slow but the car feels like it just wants to stall out.
Old Mar 26, 2007 | 11:23 AM
I meant slow as in low rpm at idle, like 300-400 instead of 550-650. But I have a feeling you should be looking at something else, like ignition system, fuel system, faulty sensors, vacuum leaks, and such. Maybe try to get the computer scanned for sensor data. Just a hunch.
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Sep 21, 2015 09:57 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
