Noticed Something When Remote Starting.........
Old Jan 30, 2007 | 09:43 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Ok,
My situation is this, in the morning when I start the car with my remote start, the car will crank and start VERY quickly, fast enough that the programmed "crank" time is actually too long....
But after the car has been run for a while around town or what not, when I try to remote start the car again, more times then not, it wont crank on the first try, having to crank one or more times for it to fire up..
WHY is it that in the mornings the car will IMMEDIATELY fire up strong, but after its been driven, take SO much longer to crank?
In the mornings, the car will crank for too long, after its driven, it sometimes has to crank more then once...WHY?
Old Jan 30, 2007 | 10:36 PM
Gramps's Avatar
Car: 87 Camaro IROC
same thing happens to me, i figure its because my fuel pump doesnt charge the system fast enuf when the engine is warm. in the mornings, the pump charges the system no problem and it fires up after half a crank. but sometimes when its warm i have to wait a few secs for the pump to prime the injectors b4 i can crank it over. i never thought anything of it, can you adjust the amout of time it cranks for?
Old Jan 30, 2007 | 10:50 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
uz got remotes to start youre cars,
I got to open my door before I can press the starter button (plus turn 2 kill switches on before the button works)
Old Jan 30, 2007 | 11:53 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Yes I can adjust the time it cranks, but as I said, If I make it crank longer to compensate warm startups...then it will DEFINATELY be WAY too much cranking after the motor has already started...
RedLeader289
May 28, 2019 01:47 PM
86IROC112
Nov 7, 2015 06:50 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
