testing pick up coil
Old Feb 11, 2007 | 06:41 PM
superirocz's Avatar
How do I test the pick up coil in my 89 iroc 350 tpi?
Old Feb 11, 2007 | 07:39 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you can test it by checking its resistance with an ohm meter, specs are 500~1500 ohms. you do have to unplug it from the module to test it.
if it checks good but the plastic connector is bad, it will still work but if the wires are hooked up to the module backwards it can cause some strange problems, anything from a no start to an intermittent misfire or poor performance.
Old Feb 11, 2007 | 08:43 PM
superirocz's Avatar
it tested good at 772
Old Feb 13, 2007 | 12:59 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
You should also test each lead for a short to the dizzy's base. There should be infinite resistence between each lead the the base of the distributor.
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
mddaniel
Sep 8, 2015 05:16 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
