..FUEL SENDER UNIT...
Old Feb 13, 2007 | 01:30 AM
stelios_z28's Avatar
Car: 1982 FIREBIRD-1983 CAMARO
Engine: 305 LG4
Transmission: TH350-TH200
my fuel sender unit is dead!!...the problem is i can't find a new one nowhere....not even on ebay..or summit..or every shop i checked on internet!all of them have plenty of sender units for 1967 to 1981 camaros!!no one has a third gen fuel sender unit!!why is this happening!please if you have a link with a shop that have that particular sender unit post it here!my car has is a 1983 4bbl z28 camaro so the sender unit is w/out fuel pump on it.thanks a lot.
Old Feb 13, 2007 | 11:05 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
BAD LINK
Old Feb 13, 2007 | 11:22 AM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
you should look around in the for sale ad's i got mine for 90$ with a brand new fuel pump works great.
Old Feb 13, 2007 | 01:33 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
http://store.summitracing.com/egnsea...115+4294776442
The link above has some aftermarket-sending units. The one you need goes from 0-90 ohms. The dealer also sells them but they want $630 for the one for my IROC. I was able to rig one a got from Autometer to work with my car although I had to get an Autometer gauge to work with it, because of different resistances. If I had known of the ones at summit I probably could have rigged those to work as well and kept the original gauge.
Old Feb 14, 2007 | 01:37 AM
Engine: 305 LG4
i just found an auction in ebay but is says that is is for 1988 injection model.maybe i can buy that one and use only the resistance to replace mine on my sender unit.both 1983 and 1985 use the same gauge.so it must fit!
Old Feb 14, 2007 | 01:41 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
The sending units on these things are the worst I've got 2 from a junk yard and I've had 2 89 camaros and the sending unit was bad on all of them.
Old Feb 14, 2007 | 02:04 AM
Engine: 305 LG4
i see your point my friend!the worst thing is that is the most difficult part to find on this particular car!
Old Oct 20, 2007 | 12:48 PM
polygaryd's Avatar
Car: 1994 firebird
Engine: 427ci lsx bowtie block
Transmission: tremec t56 micro edged gears
Axle/Gears: Strange dana 60 with racing spool
Re: ..FUEL SENDER UNIT...
i am looking for an 84 sending unit as well. i am putting it in an 85 iroc that had a 305 tpi but i put in a 350 carb engine and i would like a stock sending unit so that the pick up tube is the correct length. right now i have a rubber hose where the electric fuel pump used to be and i am sure it isnt the correct length and also the fuel gauge is messed up so i am wanting to replace the whole unit. i also need one so i can copy it for my 87 GTA where i am putting in a 427 lsx block that is suposedly going to produce mid 700 horse and i need a half inch ID line comming out of the tank so i want to copy the original 3/8 sending unti just with 1/2 inch ID line with an external aeromotive A1000 pump so i never have to take my tank down again. any help would be appreciated as i have also looked and checked with the dealer even and this part is nowhere to be found and discontinued from GM.
tommy z-28
Oct 6, 2015 10:58 PM
eustodp
Sep 20, 2015 05:09 PM
CatmanFS
Sep 19, 2015 09:00 AM
Springster
Sep 13, 2015 01:38 PM
Ironhead38
Sep 7, 2015 02:26 PM
