Power cuts out when I try to start
Old Feb 14, 2007 | 05:05 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
The battery is fully charged and all of the lights are bright and all seems fine but when I turn the key to engage the starter everything goes dead. The starter never even begins to crank the engine over. It has done this a couple times before and after 20 seconds or so something would click and everything would come back on and then I could try again, and eventually it would start. Now it doesn't even want to click the power back on. Any ideas?
Old Feb 14, 2007 | 07:21 PM
yt91rs's Avatar
Car: 91 camaro RS
Engine: 305 TBI
Transmission: Auto 4 O/D
Axle/Gears: which one i have broke three
mine use to do that it turned out to be a loose ground on the battery just enough to where it would turn sometimes but not all the time bought a new terminal bolt and it works just fine.
Old Feb 15, 2007 | 01:16 AM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
i have had this on my Camaro several times.....and had people call me saying they had a starter problem. Check all your battery connections as well as your chasis and body ground connections.
Old Feb 15, 2007 | 11:06 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
All true, it's just a bad connection, most likely on the battery cables. Clean the terminals and posts perfectly and make sure they are on tight. Happened to me before too.
Lou
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
L98GTA87
Aug 5, 2015 11:02 PM
