Brake and Tail light problem
Old Feb 19, 2007 | 09:45 AM
AKATDOG's Avatar
Car: 84 Z28
Hi, new to this place, i heard it was a great source for info, i have an 84 Z28, problem is i got no tail or brake lights, everytime i put a fuse in it blows as soon as i pull the light ****, any help much appreciated, Thanks.
Old Feb 21, 2007 | 12:10 PM
AKATDOG's Avatar
Car: 84 Z28
ok, is there a diagram available showing how to rewire my rear lights ? Any tips much appreciated.
Old Feb 21, 2007 | 01:15 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Before jumping into rewiring, check your sockets and wiring you for broken of shorted to ground More than likely you will find a bad socket causing the problem. Possibly a bad bulb. That's a lot easier that stringing wire.
http://www.autozone.com/servlet/UiBr...3d80163fb5.jsp
Fig 16 should give you what you need.
Old Feb 22, 2007 | 07:41 AM
AKATDOG's Avatar
Car: 84 Z28
ya rewiring would deffinately be my last option, Info is great, Much appreciated
Old Feb 22, 2007 | 05:59 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Put a test light across the fuse terminals, pull out the **** & the light should light - dead short to ground. With the test light on start eliminating things in the circuit - start at light sockets like bilms01 said above. As long as light is on, short to ground exists.
Happy Hunting,
Corky
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
