Vats bypassing?
Old Feb 27, 2007 | 10:09 PM
NHRA427's Avatar
Car: 94 Trans Am
Engine: LT-!
Vats bypassing?
I bought this 89 with a v6. The former owner tore all the dash out looking for a problem. I know now its a vats key car and I dont have it. All I have is a standard key without the resistor. I put the dash back together and the car would crank but not start. I found that he grounded the start relay so it would crank. I hooked it back up the way its suppose to be and have gone through the resistors to bypass it, still nothing. No cranking or anything. 1 thing thats bugging me is it says if the car is tried with the wrong key the security light should flash and it doesnt. just comes on with the key in the run or start position. Is there any other way of getting around this thing?
Old Feb 28, 2007 | 08:32 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the factory VATS module may be bad or there maybe other problems with the system.
painless wiring sells a module to bypass the VATS part of the ECM or you can remove VATS from the chip by editing the bin & burning a chip.
for the starter part, you can put a jumper across the connector terminals.
junior419
Apr 7, 2025 11:35 AM
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
Racerx974
Sep 19, 2015 10:16 AM
