Mar 6, 2007 | 09:08 PM
I'm having some trouble with the stock sound system, it (along with my interior light) no longer works. I replaced the battery because my windows, locks, etc stopped working and it didn't solve the other two problems. Could it be a fuse? Any helpful information I'd appreciate.
Robbie
Reply 0
Mar 7, 2007 | 05:49 AM
Use a test light to check your fuses first. Turn ignition to run position, ground one side of your test light and probe both sides of each fuse - light on both side of fuse = OK, light on one side only = pull fuse and check. More than likely, you will find a fuse blown.
Corky
Reply 0
Mar 7, 2007 | 05:59 PM
Thanks a ton, it saves me plenty of money by (hopefully) not putting it in the shop.
Reply 0
Subscribe
