Installing Aftermarket Tachometer
Old Mar 8, 2007 | 08:11 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I bought an aftermarket tachometer and had a question about installation. I will probably tap the 12v and illumination wires into the fuse box, the ground wire will be easy, im just wondering about the green wire that needs to tap into the coil wire. What color will the coil wire be? I have the stock HEI distributor with the in-cap coil. Any help is appreciated. Hoping to install it tommorow.
Old Mar 10, 2007 | 08:43 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
According to Chiltons, on a carbed motor the tach wire is black. On a crossfire the tach wire is white. Good luck, if you haven't already finished it.
Frozer!!!
Jan 19, 2024 04:55 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
ChevyZ71
Aug 13, 2015 07:30 AM
