Power antenna failed
Old Mar 9, 2007 | 04:19 PM
mbrownone's Avatar
Car: 3rd Gen Trans Am
Where can I locate a replacement power antenna for my 1984 TA?? Mine would keep running and I had to remove the fuse to protect my battery. Universal ones may not fit, so Im wondering if there is anyone who has some experience with this. Probably the only way to access it is to remove the fender(??), but I would really appreciate some direction from your suggestions. Thanks!
Old Mar 9, 2007 | 10:44 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You don't have to remove the fender but it's easier to remove the wheels and undo the back section of the inner fender.This will give you access to the antenna assembly.The wiring passes thru the bulkhead so you have to remove the passenger kick panel and sound panel to access the wiring.This way you will be able to unplug the electrical connections and the antenna lead you can remove to screws on the antenna body so you don't have to pull the radio.
As for your problem,it's a common one for power antennas,the nylon drive cable is most probably broken.You can buy replacement parts from one of the board sponsors Modern Day Muscle(home page http://www.moderndaymuscle.com/ and the antenna parts http://www.moderndaymuscle.com/inc/s...tenna&n=332002 ).The replacement antenna assemblys GM sells are universal units and not specific to the F-Body.
Hope this info help.
Old Mar 19, 2007 | 08:11 PM
mbrownone's Avatar
thanks. im going to take a closer look at the entire assembly when the weather gets better. the way you explained it seems fairly straight forward with a little patience.
really miss that antenna too and the stereo is worthless without it working properly...
Old Mar 19, 2007 | 08:30 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
recently i pulled off my fender and figured while it was off i would investigate the non working antenna. not sure the cause but the wires were all rusted and the insides seemed to be seized. i took it out but just cut the wires at the antenna body. do those wires lead to a connector that can be removed and replaced or i just run new wires?
Old Mar 20, 2007 | 12:02 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
The wires should run to a connector/relay under the dash, just to the left of the ECM, when facing the front of the car. The antenna wire should go directly to the back of the radio.
Dave
Old Mar 21, 2007 | 10:04 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Re: Power antenna failed
do the wires go through the firewall or are they with the bulkhead?
Old Mar 21, 2007 | 11:11 PM
PAformula's Avatar
the wires go thru a hole in the side of the firewall. Once you remove your fender liner, you can easily see the round grommet that pulls out. I just got done rebuilding mine.
Old Mar 23, 2007 | 11:52 AM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
got the wires out. thanks for the help. when you order a new antenna do they come with the grommet wires antenna cable? also whats a good place to get a oem antenna?
Old Mar 23, 2007 | 01:51 PM
PAformula's Avatar
I recommend rebuilding the one you have.
Old Mar 23, 2007 | 04:11 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
its long gone(i think), when i got it the antenna was broken about halfway up and when i benchtested it there was a humming noise and it started smoking. its either buried in my shed or i tossed it. damn
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
Papaginos
Sep 27, 2015 03:29 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
