sunpro tach
Old Mar 23, 2007 | 08:59 PM
mr iroc's Avatar
Car: 88 iroc
Transmission: 5 speed
Axle/Gears: dount know
sunpro tach
im in stalling a sunpro tachII on my 88 camaro 305 tpi 5 speed what i need to know is whar to hook the green wire hooks up to thar it sposed to go to the dis if some 1 has pics of thar install would like to see
Old Mar 24, 2007 | 10:32 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: sunpro tach
Im sure this is the wire you need to hook up. (see attachments)
Old Mar 25, 2007 | 03:43 PM
mr iroc's Avatar
Car: 88 iroc
Re: sunpro tach
thaxs i will try it out today
Old Mar 27, 2007 | 01:14 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Axle/Gears: standard 3.23
Re: sunpro tach
if you look at the distributor cap there are 2 clips on the drivers side and one of them says "tach" (should be the one oon the left) and should be a yellow(ish) wire. You should be able to take it from there...
Old Mar 28, 2007 | 01:34 AM
mr iroc's Avatar
Car: 88 iroc
Re: sunpro tach
can i just back prbe the plug or just spice the wire?
Old Mar 28, 2007 | 07:46 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: sunpro tach
the non computer controlled GM HEI has a tach output, and IIRC the coil in cap HEI does as well. If not, you should be able to splice into the white wire on your external coil.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
